Use the following procedure to delete a file from an external USB device.
Caution
Always use the usb-stop command to safely unplug the USB drive from the USB slot.
Switch:1#enable
Switch:1#delete /usb/test.cfg Are you sure (y/n) ? y
The following table defines parameters for the delete command.
Variable |
Value |
WORD<1–255> |
Specifies the file name in the following format:
